跳转到主内容
How to Repair an Unstable Sliding Door
你所需要的
  1. How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: 步骤 1 中的图像 1,3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: 步骤 1 中的图像 2,3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: 步骤 1 中的图像 3,3
    • Investigate the cause of the unstable sliding door.
    • In this case you can see the sliding tract isn't aligned with the bottom roller.
    • You can also see that the screw at the base has been dislodged.
  2. How to Repair an Unstable Sliding Door: 步骤 2 中的图像 1,3 How to Repair an Unstable Sliding Door: 步骤 2 中的图像 2,3 How to Repair an Unstable Sliding Door: 步骤 2 中的图像 3,3
    • Remove the screws used to hold the door in place with a Phillips screwdriver.
    • Once the doors are loose from the tracks, remove them.
  3. How to Repair an Unstable Sliding Door: 步骤 3 中的图像 1,3 How to Repair an Unstable Sliding Door: 步骤 3 中的图像 2,3 How to Repair an Unstable Sliding Door: 步骤 3 中的图像 3,3
    • Check to see that the rollers are securely in place.
    • If there are any bits of debris present on the rollers or the tracks, clean it off with isopropyl alcohol and a clean rag.
  4. How to Repair an Unstable Sliding Door: 步骤 4 中的图像 1,3 How to Repair an Unstable Sliding Door: 步骤 4 中的图像 2,3 How to Repair an Unstable Sliding Door: 步骤 4 中的图像 3,3
    • Place the doors back on the rollers.
    • Replace the screws you removed earlier.
    • Check that the rollers move freely. You can test this by using your hands to roll them forward to your satisfaction.
  5. How to Repair an Unstable Sliding Door: 步骤 5 中的图像 1,3 How to Repair an Unstable Sliding Door: 步骤 5 中的图像 2,3 How to Repair an Unstable Sliding Door: 步骤 5 中的图像 3,3
    • Align the door on both tracks.
    • Start by attaching the head of the door first and then lower body into the track. Avoid forcing into the track as this might damage the rollers.
    • Make sure that it is aligned properly so it does not fall out in the future.
终点
另外一个人完成了本指南。
Barabonye Longjohn
于09/21/20注册
142 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 1,172
