跳转到主内容
加入维修社区 - 创建账户
How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista
你所需要的
  1. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista, How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 1 中的图像 1,1
    • When there is water leakage from the steam valve, there are 2 sources, external and internal. External leaks are a matter of replacing bushings and shown eslewhere. This guide shows how to deal with internal leakage. First, descale the machine with a commercial product, like Dezcal. Unplug the machine from the power source then follow the steps:
    询问修复机器人
    添加评论
  2. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 2 中的图像 1,2 How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 2 中的图像 2,2
    • Remove the six screws holding down the cover. Note that the top screws have fine threads, while the four lower screws have coarse threads. Keep this in mind for later reassembly. Once the screws are off, remove the cover.
    询问修复机器人
    添加评论
  3. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 3 中的图像 1,2 How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 3 中的图像 2,2
    • Note where the steam valve knob connects to the valve assemble, at the top is a small hex nut. Use the 2mm hex wrench to loosen the nut by turning it counter clockwise, about 1/4 turn. Hold on to the wrench, keeping the steam knob shaft in the upright position.
    询问修复机器人
    添加评论
  4. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 4 中的图像 1,1
    • Now, while bracing the hex wrench, turn the steam valve knob slightly in a clockwise direction, perhaps 1/8th of a turn or less. This is compressing the seat of the steam valve plunger to close off the water leak when the machine is on.
    询问修复机器人
    添加评论
  5. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 5 中的图像 1,1
    • Tighten the hex nut firmly.
    询问修复机器人
    添加评论
  6. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 6 中的图像 1,2 How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 6 中的图像 2,2
    • Replace the cover, making sure the steel lip at the front is in its slot, and that the black plastic bushing is in place at the back of the cover. Replace two of the six screws, to save time in case you have to repeat the process.
    添加评论
    • Load and pour an espresso shot, and check the steam wand for leaks. If the wand is still leaking, go through the steps a second time.
    询问修复机器人
    添加评论
  7. How to Repair an Internal Leak in the Steam Wand of a Starbucks Barista: 步骤 8 中的图像 1,1
    • If the steam wand is still leaking after a second try, then the steam valve plunger needs to be replaced. This is part number 8 on the schematic. Overhaul kits can be acquired from sources like espressocare.com. You can follow the tear down instructions on this site, or some of the video sources on youtube.com.
    添加评论
结论
If the wand still leaks after trying this, a more detailed repair is required.
取消:我没有完成这个指南。
9等其他人完成本指南。
mike davis
于09/16/18注册
409 声望
撰写一个指南
4指南评论
A well thought out repair. However, the internal part that needs to be replaced is actually part number 9, which is the actual gasket for the steam valve plunger. I’ve done this on my old Saeco Barista and it worked well. My machine is 16 years old and the boiler works like a furnace. These are excellent machines.
mike davis - 回复 分享
From where did you buy the part, please?
JOHN L HERRING - 回复 分享
I get my parts from Ebay, the seller is called coffeesection , parts ship from Bulgaria. He has everything you would need, his shipping prices seem high but he will provide free shipping if you do not demand tracked shipping.
mike davis - 回复 分享
Fixed!! 👩🏼‍🔧
It wasn't really a leak, it was more of a powerful spray from my steam wand everytime I pulled a shot. I developed the makeshift method of turning the steam valve knob as tightly closed as I could to reduce the spray to a drip while a shot was pulling, but it was getting harder and harder to fight the water back.
I almost gave up on my 20 year old machine, but this guide did the trick!
Thanks so much! It seems like I'll get a few more years out of this machine yet ☕
Andrea Gardner - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 70
总计 5,022
