跳转到主内容
How to Repair a Whiteboard Frame
你所需要的
  1. How to Repair a Whiteboard Frame, How to Repair a Whiteboard Frame: 步骤 1 中的图像 1,1
    • Gather all your tools which are listed in the tool area.
  2. How to Repair a Whiteboard Frame: 步骤 2 中的图像 1,2 How to Repair a Whiteboard Frame: 步骤 2 中的图像 2,2
    • Start by applying Goo Gone onto a paper towel to remove any sticky residue from the outside of the whiteboard.
  3. How to Repair a Whiteboard Frame: 步骤 3 中的图像 1,3 How to Repair a Whiteboard Frame: 步骤 3 中的图像 2,3 How to Repair a Whiteboard Frame: 步骤 3 中的图像 3,3
    • Clean the surface using a multipurpose cleaner safe for wood to remove any remaining residue and debris
  4. How to Repair a Whiteboard Frame: 步骤 4 中的图像 1,3 How to Repair a Whiteboard Frame: 步骤 4 中的图像 2,3 How to Repair a Whiteboard Frame: 步骤 4 中的图像 3,3
    • Apply an even amount of glue to each piece, then place them into position and wipe off any excess glue
  5. How to Repair a Whiteboard Frame: 步骤 5 中的图像 1,1
    • Hold all the pieces together for a minute to allow the glue to set firmly.
  6. How to Repair a Whiteboard Frame: 步骤 6 中的图像 1,3 How to Repair a Whiteboard Frame: 步骤 6 中的图像 2,3 How to Repair a Whiteboard Frame: 步骤 6 中的图像 3,3
    • Secure the pieces with clamps at the corners and wait for 24 hours to let the glue dry.
  7. How to Repair a Whiteboard Frame: 步骤 7 中的图像 1,2 How to Repair a Whiteboard Frame: 步骤 7 中的图像 2,2
    • After 24 Hours, remove the clamps carefully.
  8. How to Repair a Whiteboard Frame: 步骤 8 中的图像 1,2 How to Repair a Whiteboard Frame: 步骤 8 中的图像 2,2
    • After 24 hours, remove the clamps and sand down any rough corners if necessary.
  9. How to Repair a Whiteboard Frame: 步骤 9 中的图像 1,2 How to Repair a Whiteboard Frame: 步骤 9 中的图像 2,2
    • Touch up any areas on the whiteboard using black paint where needed.
  10. How to Repair a Whiteboard Frame: 步骤 10 中的图像 1,1
    • Congratulations! Your whiteboard is now fixed and ready to use.
结论
Jelena Drca
于02/02/24注册
181 声望
撰写一个指南
团队
UC Davis, Team 3-9, Andersen Winter 2024 UC Davis, Team 3-9, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S3G9
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 36
总计 526
