跳转到主内容
How to Repair a Warped Cooking Pan
你所需要的
  1. How to Repair a Warped Cooking Pan, How to Repair a Warped Cooking Pan: 步骤 1 中的图像 1,1
    • Locate the hard surface you will use for the repair.
  2. How to Repair a Warped Cooking Pan: 步骤 2 中的图像 1,1
    • Place one of the two towels on top of the hard surface.
  3. How to Repair a Warped Cooking Pan: 步骤 3 中的图像 1,1
    • Turn on the stove to medium heat to warm up the bottom of the cooking pan that is warped.
  4. How to Repair a Warped Cooking Pan: 步骤 4 中的图像 1,1
    • As soon as the pan is warm or hot to the touch, quickly remove it from the stove.
    • Turn off the stove and place the pan, bottom up, on top of the towel that is placed on the hard surface.
  5. How to Repair a Warped Cooking Pan: 步骤 5 中的图像 1,2 How to Repair a Warped Cooking Pan: 步骤 5 中的图像 2,2
    • Place the second towel on top of the bottom of the pan that is facing upward.
  6. How to Repair a Warped Cooking Pan: 步骤 6 中的图像 1,1
    • Place the block of wood on top of the second towel that is placed on the pan.
  7. How to Repair a Warped Cooking Pan: 步骤 7 中的图像 1,2 How to Repair a Warped Cooking Pan: 步骤 7 中的图像 2,2
    • Carefully hammer directly onto the block of wood.
    • Make sure that the block of wood is still firmly on top of the bottom of the pan. This will help ensure that the pan is repaired properly.
  8. How to Repair a Warped Cooking Pan: 步骤 8 中的图像 1,1
    • Your cooking pan should no longer be warped. You are finished!
终点
angieaguirre
于02/21/24注册
157 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 262
