跳转到主内容
How to Repair a Vileda Turbo Mop Bucket Set
你所需要的
  1. How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: 步骤 1 中的图像 1,2 How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: 步骤 1 中的图像 2,2
    • No Parts Required
  2. How to Repair a Vileda Turbo Mop Bucket Set: 步骤 2 中的图像 1,1
    • Run the few drops of oil down the chrome shaft
结论
Get back to work !
3等其他人完成本指南。
Paul
于10/09/12注册
768 声望
创作了4篇指南
8条评论
I had the same problem but fixed it slightly different. I turned the empty bucket upside down, removed the four pz2 screws. Lifted out gearing in one piece. Removed rust/debris from two month old bucket stainless steel shaft and sprayed with water dispersant liquid. Reassembled. May sound complicated but very easy and thorough job. Only about 10 minutes, screwdriver and lubricant spray.
jimdeane77 - 回复
Hi Jim Thanks for your idea. Next time I will go a bit deeper into it. My bucket was already full and ready to go. The few drops of oil got it going straight away.
Paul - 回复
Sometimes there is too much rust into the gearing.
I replace it with “Octagonal One Way Needle Roller Bearing HF081412 8*14*12mm Fit for EasyMop” found on EBAY (10=$8.90 !)
Like a new ! I takes 10’ !
geek5537 - 回复
Thanks for the heads up , geek5537. Will take note of the part number. Stay safe.
Paul - 回复
Where I can buy new pedal? Mine is broken.
Emil Hakobian - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 127
过去 30 天: 553
总计 22,435
