跳转到主内容
How to Repair a Trophy
你所需要的
  1. How to Repair a Trophy, How to Repair a Trophy: 步骤 1 中的图像 1,3 How to Repair a Trophy, How to Repair a Trophy: 步骤 1 中的图像 2,3 How to Repair a Trophy, How to Repair a Trophy: 步骤 1 中的图像 3,3
    • Put the cylindrical tube on the small threaded rod of the cup.
    • Turn to the right until you tighten it completely.
  2. How to Repair a Trophy: 步骤 2 中的图像 1,3 How to Repair a Trophy: 步骤 2 中的图像 2,3 How to Repair a Trophy: 步骤 2 中的图像 3,3
    • Place the longest threaded rod on the opposite side of the cylindrical tube and twist again to the right until it is tight.
  3. How to Repair a Trophy: 步骤 3 中的图像 1,3 How to Repair a Trophy: 步骤 3 中的图像 2,3 How to Repair a Trophy: 步骤 3 中的图像 3,3
    • Put all the pieces on in the correct order.
    • If you put them on in the wrong order they won't fit.
  4. How to Repair a Trophy: 步骤 4 中的图像 1,3 How to Repair a Trophy: 步骤 4 中的图像 2,3 How to Repair a Trophy: 步骤 4 中的图像 3,3
    • Insert the nut into the hub of the 3/8 drive ratchet wrench.
    • Use the 3/8 inch ratchet wrench to secure the nut at the bottom of the trophy. Turn the nut clockwise until it is fully secure.
  5. How to Repair a Trophy: 步骤 5 中的图像 1,3 How to Repair a Trophy: 步骤 5 中的图像 2,3 How to Repair a Trophy: 步骤 5 中的图像 3,3
    • Glue the remaining two pieces to the side of the trophy.
    • Allow them to dry before touching to prevent them from coming off.
  6. How to Repair a Trophy: 步骤 6 中的图像 1,1
    • Wait some time (approximately 30 minutes) until the pieces have dried completely.
    • And your done!!
结论
This work will be completed when all the pieces are tight and without coming off. Remember not to touch the glued pieces too much to avoid breaking them again. I hope you had fun arranging a good memory.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 65
总计 2,878
