跳转到主内容
How to Repair a Torn Leather Boot
你所需要的
  1. How to Repair a Torn Leather Boot, How to Repair a Torn Leather Boot: 步骤 1 中的图像 1,3 How to Repair a Torn Leather Boot, How to Repair a Torn Leather Boot: 步骤 1 中的图像 2,3 How to Repair a Torn Leather Boot, How to Repair a Torn Leather Boot: 步骤 1 中的图像 3,3
    • Prepare your leather boot with the listed materials:
    • Shoo Glue
    • Paper Towels
  2. How to Repair a Torn Leather Boot: 步骤 2 中的图像 1,1
    • Remove any lacing on the boots
    • This allows for spacing within the shoes to make it easier to navigate through the process of the fix.
  3. How to Repair a Torn Leather Boot: 步骤 3 中的图像 1,1
    • Using alcohol wipes or any leather cleansing products, clean targeted and surrounding area to rid debris.
    • Once clean make sure that the surrounding area is dried off properly before moving onto the next step.
  4. How to Repair a Torn Leather Boot: 步骤 4 中的图像 1,2 How to Repair a Torn Leather Boot: 步骤 4 中的图像 2,2
    • Fill the boot with a paper towel, rag, or piece of cloth.
    • Gives the boot proper shape and protects interior from glue.
    • Filling is sufficient when the tear protrudes slightly.
  5. How to Repair a Torn Leather Boot: 步骤 5 中的图像 1,2 How to Repair a Torn Leather Boot: 步骤 5 中的图像 2,2
    • Apply "Shoe Goo" on the damaged area with a Cotton Swab.
  6. How to Repair a Torn Leather Boot: 步骤 6 中的图像 1,1
    • Set a 10 minute timer to allow for the glue to dry. Make sure that the shoes are dried before proceeding on to the next step.
  7. How to Repair a Torn Leather Boot: 步骤 7 中的图像 1,1
    • After the Shoe Goo has fully dried make sure to clean up any excess Goo from the shoe that is unnecessary for the repair.
    • Remove any of the towels, or rags that were originally inserted within the shoes.
    • Finally re-lace the boots to finalize the procedure.
结论
After completing all the listed steps above your shoes should be repaired and ready to go. By applying Shoe Goo to your product you have restored the life of your item once again. This procedure is very simple and can be completed several times on the same item.
Alexander Arellano
于02/03/23注册
145 声望
撰写一个指南
团队
UC Davis, Team 3-3, Andersen Winter 2023 UC Davis, Team 3-3, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S3G3
3 名成员
创作了2篇指南
一条评论
Why shoe goo? The end result is a clear semi-clear goo appearance that cant be dyed or colored.
Trenton Harbour - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 77
总计 4,525
