跳转到主内容
加入维修社区 - 创建账户
How to Repair a Tear Inside a Backpack
你所需要的
    1. How to Repair a Tear Inside a Backpack, How to Repair a Tear Inside a Backpack: 步骤 1 中的图像 1,1
      • First use scissors to cut off the destroyed nylon material inside of the backpack.
      询问修复机器人
      添加评论
    2. How to Repair a Tear Inside a Backpack: 步骤 2 中的图像 1,1
      • Using a ruler, cut out the appropriate length of nylon material to cover the tear inside of the backpack.
      • The nylon material needed for the tear size will be different for each backpack. Measure out how much material you need to cover the tear.
      询问修复机器人
      添加评论
    3. How to Repair a Tear Inside a Backpack: 步骤 3 中的图像 1,1
      • Use push-pins to pin down each corner of the nylon material.
      询问修复机器人
      添加评论
    4. How to Repair a Tear Inside a Backpack: 步骤 4 中的图像 1,1
      • Put thread through the needle. Double knot the thread to secure it on the needle. Then cut the end of the thread and the double knot as well.
      询问修复机器人
      添加评论
    5. How to Repair a Tear Inside a Backpack: 步骤 5 中的图像 1,1
      • A basic stitch will suffice. To do a basic stitch, just poke the needle through the nylon material until it is on the other side. Bring all of the thread through. Then push the needle back near the thread that was pulled through.
      • Be careful not to poke yourself with the needle.
      询问修复机器人
      添加评论
    6. How to Repair a Tear Inside a Backpack: 步骤 6 中的图像 1,1
      • Repeat until the nylon material is secure. This picture is an example of what a basic stitch should look like after repeating the stitch.
      询问修复机器人
      添加评论
    7. How to Repair a Tear Inside a Backpack: 步骤 7 中的图像 1,1
      • Once finished cut the remaining thread and double knot the thread. Trim off any excess nylon material that is not sewn down. If the nylon is secure, you have fully fixed the tear!
      添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Missouri Western, Team 1-6, Adkins Fall 2015 Missouri Western, Team 1-6, Adkins Fall 2015 的会员
MWSU-ADKINS-F15S1G6
1 名成员
创作了1篇指南
2指南评论
My Lock Lock Luggage inside the “ inner cover got damage “ can repair ? where should deliver to ? how much for the cost?
衛德雄 - 回复 分享
Have you seen this product? "'''fixmytear'''". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 91
总计 14,890
