跳转到主内容
How to Repair a Stuck or Broken Chainsaw Rope
你所需要的
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: 步骤 1 中的图像 1,2 How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: 步骤 1 中的图像 2,2
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 2 中的图像 1,1
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 3 中的图像 1,2 How to Repair a Stuck or Broken Chainsaw Rope: 步骤 3 中的图像 2,2
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 4 中的图像 1,2 How to Repair a Stuck or Broken Chainsaw Rope: 步骤 4 中的图像 2,2
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 5 中的图像 1,1
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 6 中的图像 1,1
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 7 中的图像 1,1
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 8 中的图像 1,1
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 9 中的图像 1,2 How to Repair a Stuck or Broken Chainsaw Rope: 步骤 9 中的图像 2,2
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 10 中的图像 1,1
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 11 中的图像 1,2 How to Repair a Stuck or Broken Chainsaw Rope: 步骤 11 中的图像 2,2
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 12 中的图像 1,1
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 13 中的图像 1,1
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: 步骤 14 中的图像 1,1
    • Pull on the rope to make sure the chainsaw works.
终点
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 623
