跳转到主内容
How to Repair a Stuck Trailer Jack
你所需要的
  1. How to Repair a Stuck Trailer Jack, How to Repair a Stuck Trailer Jack: 步骤 1 中的图像 1,1
    • Remove the trailer jack from trailer.
    • Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
    • Slide the jack off the trailer to remove.
    • Be sure to safely support the trailer before removing (With a vehicle or jack stands).
  2. How to Repair a Stuck Trailer Jack: 步骤 2 中的图像 1,1
    • Remove the nut and bolt that secures the handle to the jack.
    • Use two half-inch box end wrenches to remove the half-inch bolt and nut.
    • Slide the handle upward after removing the nut and bolt to remove the handle.
    • Set the handle aside.
    • Screw the jack to the most extended spot the jack will go.
  3. How to Repair a Stuck Trailer Jack: 步骤 3 中的图像 1,1
    • Lift the spacer or washer upward.
    • Set the washer aside.
  4. How to Repair a Stuck Trailer Jack: 步骤 4 中的图像 1,1
    • Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
    • Set the upper assembly aside.
  5. How to Repair a Stuck Trailer Jack: 步骤 5 中的图像 1,1
    • Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
  6. How to Repair a Stuck Trailer Jack: 步骤 6 中的图像 1,1
    • Apply grease or anti-seize lubricant to the screw assembly.
    • Screw the screw assembly to full extension and shortest extension to ensure lubricant reaches every section of the screw assembly.
  7. How to Repair a Stuck Trailer Jack: 步骤 7 中的图像 1,1
    • Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
  8. How to Repair a Stuck Trailer Jack: 步骤 8 中的图像 1,1
    • Paint the upper and lower assemblies for prevention of future rust and corrosion.
  9. How to Repair a Stuck Trailer Jack: 步骤 9 中的图像 1,1
    • During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
  10. How to Repair a Stuck Trailer Jack: 步骤 10 中的图像 1,1
    • Use a hammer to force the upper assembly over the lower assembly.
    • Be sure to align the grove and notch of the assemblies.
  11. How to Repair a Stuck Trailer Jack: 步骤 11 中的图像 1,1
    • Install the washer and the jack handle over the stud of the jack.
    • Insert the bolt through the handle and the hole located on the stud.
  12. How to Repair a Stuck Trailer Jack: 步骤 12 中的图像 1,1
    • Install the jack to the trailer and test for correct operation.
结论
3等其他人完成本指南。
一条评论
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
Loren Turner - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 112
过去 30 天: 572
总计 17,206
