跳转到主内容
How to Repair a Stuck Car Door Latch
你所需要的
  1. How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: 步骤 1 中的图像 1,2 How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: 步骤 1 中的图像 2,2
    • On the car door that will not close, examine the door latch located near the handle on the side of the door.
    • The car door latch will be locked in a closed position.
  2. How to Repair a Stuck Car Door Latch: 步骤 2 中的图像 1,3 How to Repair a Stuck Car Door Latch: 步骤 2 中的图像 2,3 How to Repair a Stuck Car Door Latch: 步骤 2 中的图像 3,3
    • Position a screwdriver between the legs of the locked door latch.
    • You may use any size screwdriver that will fit between the latch.
  3. How to Repair a Stuck Car Door Latch: 步骤 3 中的图像 1,1
    • Pull the exterior car door handle.
  4. How to Repair a Stuck Car Door Latch: 步骤 4 中的图像 1,2 How to Repair a Stuck Car Door Latch: 步骤 4 中的图像 2,2
    • While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
  5. How to Repair a Stuck Car Door Latch: 步骤 5 中的图像 1,3 How to Repair a Stuck Car Door Latch: 步骤 5 中的图像 2,3 How to Repair a Stuck Car Door Latch: 步骤 5 中的图像 3,3
    • Use the screwdriver to push the latch upwards into the final unlocked position.
  6. How to Repair a Stuck Car Door Latch: 步骤 6 中的图像 1,2 How to Repair a Stuck Car Door Latch: 步骤 6 中的图像 2,2
    • Close the car door to ensure the latch has been properly reset.
终点
12等其他人完成本指南。
团队
UW Tacoma, Team S1-G30, Cardinal Spring 2020 UW Tacoma, Team S1-G30, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G30
1 名成员
创作了5篇指南
14条评论
Thanks a lot, you have saved me from one !&&* of a problem!
dee Knight - 回复
This helped me so much!! Thank you!!!
Jasmine Roman - 回复
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Bill Smith - 回复
Thank you so much! I figured it out because of this post!
Sharan Sahota - 回复
I love this solution. It literally just saved me. Thank you soo much.
Edith Turkson - 回复
添加评论
浏览统计数据:
过去 24 小时: 190
过去 7 天: 1,309
过去 30 天: 6,077
总计 124,717
