跳转到主内容
How to Repair a Squier Affinity Stratocaster Guitar Jack
你所需要的
  1. How to Repair a Squier Affinity Stratocaster Guitar Jack, Input Jack: 步骤 1 中的图像 1,1
    • Test the sound output via amplifier, and then set it to zero.
    • Keeping the amplifier on with the guitar connected to it may produce unpleasant static depending on how loose the jack is. Make sure to turn it off before proceeding.
  2. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 2 中的图像 1,1
    • Using the Phillips #3 screwdriver, remove the two 1.2 mm screws that are connected to the plate.
  3. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 3 中的图像 1,1
    • Remove the plate without touching the jack.
    • Fixing the jack without removing the plate can cause broken wires. Do not tighten the bolt connecting the jack before taking off the plate.
  4. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 4 中的图像 1,3 How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 4 中的图像 2,3 How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 4 中的图像 3,3
    • Take the jack out of the guitar.
    • Here, you can examine the wires and check for any interior damages.
  5. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 5 中的图像 1,1
    • Carefully tighten the outside of the jack using a wrench.
    • If you do not have an adjustable wrench, use an ESP Multi Spanner.
  6. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 6 中的图像 1,1
    • Carefully reconnect the plate back on using your screwdriver.
  7. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 7 中的图像 1,1
    • Readjust the output settings on your guitar, and plug in your audio cable.
  8. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 8 中的图像 1,1
    • Test the tightness of your input jack before plugging your audio cable into your amplifier.
  9. How to Repair a Squier Affinity Stratocaster Guitar Jack: 步骤 9 中的图像 1,1
    • Plug the guitar into the amplifier to test the audio cable sensitivity and output quality.
结论
That is all you need to do to fix your Squier Affinity Stratocaster’s input jack. Now have fun making music!
3等其他人完成本指南。
Maryam Ahmed
于05/12/21注册
273 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 76
总计 3,042
