跳转到主内容
How to Repair a Silent Wall Clock Mechanism
你所需要的
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: 步骤 1 中的图像 1,1
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: 步骤 2 中的图像 1,1
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: 步骤 3 中的图像 1,1
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: 步骤 4 中的图像 1,1
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: 步骤 5 中的图像 1,1
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: 步骤 6 中的图像 1,1
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: 步骤 7 中的图像 1,1
    • Put the faceplate back on and assemble all of the pieces of the clock.
结论
5等其他人完成本指南。
团队
2指南评论
catellano por favor.gracias.
mario oscar Fiori - 回复
You don't need to open the clock to set the time - just turn that circle dial on the backside of the clock! What is this guide "fixing" anyway??
Ari - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 147
总计 7,782
