跳转到主内容
How to Repair a Seam Split in a Winter Glove
你所需要的
  1. How to Repair a Seam Split in a Winter Glove, Identify the repair area: 步骤 1 中的图像 1,3 How to Repair a Seam Split in a Winter Glove, Identify the repair area: 步骤 1 中的图像 2,3 How to Repair a Seam Split in a Winter Glove, Identify the repair area: 步骤 1 中的图像 3,3
    • Locate the seam split that needs to be fixed.
    • Collect all the tools needed for the repair.
  2. How to Repair a Seam Split in a Winter Glove, Prepare the glove: 步骤 2 中的图像 1,3 How to Repair a Seam Split in a Winter Glove, Prepare the glove: 步骤 2 中的图像 2,3 How to Repair a Seam Split in a Winter Glove, Prepare the glove: 步骤 2 中的图像 3,3
    • Turn the glove "inside-out" to make the stitching in the next steps easier.
  3. How to Repair a Seam Split in a Winter Glove, Prepare for stitching: 步骤 3 中的图像 1,2 How to Repair a Seam Split in a Winter Glove, Prepare for stitching: 步骤 3 中的图像 2,2
    • Insert the thread into the needle and make a small knot in the end.
    • Note: For this fix the repair is going to be "invisible" so it does matter the color of thread you choose.
  4. How to Repair a Seam Split in a Winter Glove, Start stitching: 步骤 4 中的图像 1,3 How to Repair a Seam Split in a Winter Glove, Start stitching: 步骤 4 中的图像 2,3 How to Repair a Seam Split in a Winter Glove, Start stitching: 步骤 4 中的图像 3,3
    • If the hole starts where the green arrow is, you should start stitching approximately 5 mm away from the start of the hole (red arrow).
  5. How to Repair a Seam Split in a Winter Glove, Continue stitching: 步骤 5 中的图像 1,3 How to Repair a Seam Split in a Winter Glove, Continue stitching: 步骤 5 中的图像 2,3 How to Repair a Seam Split in a Winter Glove, Continue stitching: 步骤 5 中的图像 3,3
    • Continue stitching until you covered the entire whole.
    • Tip: Always insert the needle back through the same side it came out from.
  6. How to Repair a Seam Split in a Winter Glove, Clean the area: 步骤 6 中的图像 1,3 How to Repair a Seam Split in a Winter Glove, Clean the area: 步骤 6 中的图像 2,3 How to Repair a Seam Split in a Winter Glove, Clean the area: 步骤 6 中的图像 3,3
    • Finish the fix with a knot at the end and cut excess thread with a pair of scissors.
  7. How to Repair a Seam Split in a Winter Glove, Finished and ready!: 步骤 7 中的图像 1,3 How to Repair a Seam Split in a Winter Glove, Finished and ready!: 步骤 7 中的图像 2,3 How to Repair a Seam Split in a Winter Glove, Finished and ready!: 步骤 7 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 16
过去 30 天: 43
总计 123
