跳转到主内容
How to Repair a Rip in a Cashmere Scarf
你所需要的
  1. How to Repair a Rip in a Cashmere Scarf, How to Repair a Rip in a Cashmere Scarf: 步骤 1 中的图像 1,2 How to Repair a Rip in a Cashmere Scarf, How to Repair a Rip in a Cashmere Scarf: 步骤 1 中的图像 2,2
    • Lay your cashmere scarf on a flat and clean surface.
  2. How to Repair a Rip in a Cashmere Scarf: 步骤 2 中的图像 1,1
    • Trim any stray/loose threads off the ripped area.
  3. How to Repair a Rip in a Cashmere Scarf: 步骤 3 中的图像 1,3 How to Repair a Rip in a Cashmere Scarf: 步骤 3 中的图像 2,3 How to Repair a Rip in a Cashmere Scarf: 步骤 3 中的图像 3,3
    • Thread your needle through the hole at the bottom and tie a knot at one end.
  4. How to Repair a Rip in a Cashmere Scarf: 步骤 4 中的图像 1,2 How to Repair a Rip in a Cashmere Scarf: 步骤 4 中的图像 2,2
    • Start your needle at the bottom of the rip to secure the end knot through a first small stitch.
  5. How to Repair a Rip in a Cashmere Scarf: 步骤 5 中的图像 1,1
    • Insert your needle across your first stitch and then do a vertical stitch.
  6. How to Repair a Rip in a Cashmere Scarf: 步骤 6 中的图像 1,1
    • Repeat this action until you have almost reached the top of the rip.
  7. How to Repair a Rip in a Cashmere Scarf: 步骤 7 中的图像 1,1
    • Gradually make the top stitches closer together.
  8. How to Repair a Rip in a Cashmere Scarf: 步骤 8 中的图像 1,3 How to Repair a Rip in a Cashmere Scarf: 步骤 8 中的图像 2,3 How to Repair a Rip in a Cashmere Scarf: 步骤 8 中的图像 3,3
    • Pull the string to close up the rip.
  9. How to Repair a Rip in a Cashmere Scarf: 步骤 9 中的图像 1,3 How to Repair a Rip in a Cashmere Scarf: 步骤 9 中的图像 2,3 How to Repair a Rip in a Cashmere Scarf: 步骤 9 中的图像 3,3
    • Secure your sewing with a knot at the back.
    • Cut off the excess sewing thread.
结论
You've completed the repair! To undo your sewing, just cut the thread and pull it out.
2等其他人完成本指南。
Mckenzie Moua
于11/07/24注册
199 声望
撰写一个指南
团队
UC Davis, Team 2-6, Vidal-Chiesa Fall 2024 UC Davis, Team 2-6, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S2G6
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 63
总计 488
