简介
This fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
你所需要的
Loosen the 4 phillips screws around the rim and remove the front of the cage
To reassemble your device, follow these steps in reverse order.
4等其他人完成本指南。
4条评论
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - 回复
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Clark Nova - 回复
Mine did the same
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
