跳转到主内容
How to Repair a Patio Solar Light
你所需要的
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: 步骤 1 中的图像 1,1
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: 步骤 2 中的图像 1,1
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: 步骤 3 中的图像 1,1
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: 步骤 4 中的图像 1,1
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: 步骤 5 中的图像 1,3 How to Repair a Patio Solar Light: 步骤 5 中的图像 2,3 How to Repair a Patio Solar Light: 步骤 5 中的图像 3,3
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: 步骤 6 中的图像 1,1
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
结论
Miguel Antonio Gonzales
于02/20/24注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 49
总计 610
