跳转到主内容
How to Repair a Painting Frame
你所需要的
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: 步骤 1 中的图像 1,3 How to Repair a Painting Frame, How to Repair a Painting Frame: 步骤 1 中的图像 2,3 How to Repair a Painting Frame, How to Repair a Painting Frame: 步骤 1 中的图像 3,3
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: 步骤 2 中的图像 1,1
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: 步骤 3 中的图像 1,1
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: 步骤 4 中的图像 1,3 How to Repair a Painting Frame: 步骤 4 中的图像 2,3 How to Repair a Painting Frame: 步骤 4 中的图像 3,3
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: 步骤 5 中的图像 1,3 How to Repair a Painting Frame: 步骤 5 中的图像 2,3 How to Repair a Painting Frame: 步骤 5 中的图像 3,3
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: 步骤 6 中的图像 1,1
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: 步骤 7 中的图像 1,2 How to Repair a Painting Frame: 步骤 7 中的图像 2,2
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: 步骤 8 中的图像 1,1
    • After that, you will have a restored painting frame.
终点
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 802
