简介
This fast fix is made for those who want to learn how to fix a metal fence by welding it together. This fix is helpful since rust and external forces (someone breaking it) might cause the bar to detach. If you learn to fix it, then you won't need to hire someone to fix it every time it breaks.
Always weld in an open area with nothing flammable around. Wear proper protection including a welding helmet, welding gloves, and safety glasses.
Not only must you weld in an open and clean space, but you must also do it while the sun is out so you can see through the welding helmet (since the visor is darkly tinted, you won't be able to see through it at night). The grinder disc size that I used in this fast fix was a size 4 1/2 inch. You can use any size because you are just using it to scrape off residue and paint.
你所需要的
Use the grinder by doing a back and forth motion to sand down the post. This clears rust buildup and paint that is left on both metal bars.
To fix your metal fence, follow these instructions in order.
2等其他人完成本指南。
