跳转到主内容
How to Repair a Loose Impress Mighty Mite Fan
你所需要的
  1. How to Repair a Loose Impress Mighty Mite Fan, How to Repair a Loose Impress Mighty Mite Fan: 步骤 1 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan, How to Repair a Loose Impress Mighty Mite Fan: 步骤 1 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan, How to Repair a Loose Impress Mighty Mite Fan: 步骤 1 中的图像 3,3
    • Remove the single 0.8 mm screw using a Phillips #2 screwdriver. Use a pair of pliers to hold the hexagon nut so that it makes the process easier.
  2. How to Repair a Loose Impress Mighty Mite Fan: 步骤 2 中的图像 1,2 How to Repair a Loose Impress Mighty Mite Fan: 步骤 2 中的图像 2,2
    • Disconnect the hinges that hold the fan covers together.
  3. How to Repair a Loose Impress Mighty Mite Fan: 步骤 3 中的图像 1,2 How to Repair a Loose Impress Mighty Mite Fan: 步骤 3 中的图像 2,2
    • Remove the front cover and set it aside.
  4. How to Repair a Loose Impress Mighty Mite Fan: 步骤 4 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 4 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 4 中的图像 3,3
    • Use the Phillips #2 screwdriver to remove the 1.4 mm screw that holds the fan blades to the fan.
  5. How to Repair a Loose Impress Mighty Mite Fan: 步骤 5 中的图像 1,2 How to Repair a Loose Impress Mighty Mite Fan: 步骤 5 中的图像 2,2
    • Remove the fan blades and set them aside.
  6. How to Repair a Loose Impress Mighty Mite Fan: 步骤 6 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 6 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 6 中的图像 3,3
    • Position the fans back cover correctly aligned with its placeholders.
    • The placeholders are small and black which are not too visible on camera. There are two placeholders and they are shaped like cylinders.
  7. How to Repair a Loose Impress Mighty Mite Fan: 步骤 7 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 7 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 7 中的图像 3,3
    • Twist the big knob clockwise, that holds the back cover, until it is tight and you can no longer twist.
    • The back cover must be correctly placed on its holders before this step.
  8. How to Repair a Loose Impress Mighty Mite Fan: 步骤 8 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 8 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 8 中的图像 3,3
    • Place the fan blades back onto the fan and start screwing the 1.4 mm cross head screw into the clockwise direction until it is flat and can no longer screw.
  9. How to Repair a Loose Impress Mighty Mite Fan: 步骤 9 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 9 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 9 中的图像 3,3
    • Place the front cover back onto the fan with the punch-holes aligned so that the small bolt can go through.
    • These punch-holes should be aligned and you should be able to see through it.
  10. How to Repair a Loose Impress Mighty Mite Fan: 步骤 10 中的图像 1,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 10 中的图像 2,3 How to Repair a Loose Impress Mighty Mite Fan: 步骤 10 中的图像 3,3
    • Place the .8 mm cross head screw back inside the punch-hole and start screwing the hexagon nut by hand so that this process is easier.
    • Do not tighten this too much as you might need to repeat the whole process in the future of your fans usage.
  11. How to Repair a Loose Impress Mighty Mite Fan: 步骤 11 中的图像 1,2 How to Repair a Loose Impress Mighty Mite Fan: 步骤 11 中的图像 2,2
    • Close the hinges so that the covers are joined back together.
结论
To repeat the process start from step 1.
Alexis S
于10/05/21注册
193 声望
撰写一个指南
团队
CSU Los Angeles, Team 11-20, Grodsky Fall 2021 CSU Los Angeles, Team 11-20, Grodsky Fall 2021 的会员
CSULA-GRODSKY-F21S11G20
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,011
