跳转到主内容
How to Repair a Locket Hinge
你所需要的
  1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: 步骤 1 中的图像 1,3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: 步骤 1 中的图像 2,3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: 步骤 1 中的图像 3,3
    • Use pliers to carefully bend the damaged hinge back into place.
    • You want the hinge to be rounded and hollow, like a straw.
    • Test the hinge with some wire. If you can easily thread the wire through, then you can move on to Step 2. If not, keep bending.
  2. How to Repair a Locket Hinge: 步骤 2 中的图像 1,3 How to Repair a Locket Hinge: 步骤 2 中的图像 2,3 How to Repair a Locket Hinge: 步骤 2 中的图像 3,3
    • Hold both ends of the wire.
    • Place the middle of the wire against a hard edge. Hold the wire so that it is perpendicular to the edge.
    • Straighten the wire by pulling it against the edge.
  3. How to Repair a Locket Hinge: 步骤 3 中的图像 1,2 How to Repair a Locket Hinge: 步骤 3 中的图像 2,2
    • Bend the wire to match the contours of your locket.
    • If your locket is rounded, your wire will have to be curved. If your locket is straight, your wire will have to be straight.
  4. How to Repair a Locket Hinge: 步骤 4 中的图像 1,2 How to Repair a Locket Hinge: 步骤 4 中的图像 2,2
    • Cut the wire to a manageable length. We suggest the length of the hinges plus some excess.
  5. How to Repair a Locket Hinge: 步骤 5 中的图像 1,3 How to Repair a Locket Hinge: 步骤 5 中的图像 2,3 How to Repair a Locket Hinge: 步骤 5 中的图像 3,3
    • Match and align the front and back of the locket.
    • The holes of the hinge must be aligned, making a tunnel for the wire.
    • Line up the curved wire to match the locket shape.
    • Feed the wire through the hole of the hinge.
  6. How to Repair a Locket Hinge: 步骤 6 中的图像 1,3 How to Repair a Locket Hinge: 步骤 6 中的图像 2,3 How to Repair a Locket Hinge: 步骤 6 中的图像 3,3
    • Hold the locket closed.
    • Glue the top of the hinge.
    • Glue the bottom of the hinge.
    • Do not glue the center of the hinge.
  7. How to Repair a Locket Hinge: 步骤 7 中的图像 1,2 How to Repair a Locket Hinge: 步骤 7 中的图像 2,2
    • Hold the locket closed and hammer the side with the hinge and wire.
    • Tap firmly along the hinge and wire to secure.
  8. How to Repair a Locket Hinge: 步骤 8 中的图像 1,2 How to Repair a Locket Hinge: 步骤 8 中的图像 2,2
    • Cut the excess wire.
  9. How to Repair a Locket Hinge: 步骤 9 中的图像 1,2 How to Repair a Locket Hinge: 步骤 9 中的图像 2,2
    • The final product, the locket hinge is fixed and the locket can be used.
终点
Daisy J Williams
于01/31/24注册
169 声望
撰写一个指南
团队
UC Davis, Team 4-3, Andersen Winter 2024 UC Davis, Team 4-3, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S4G3
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 40
总计 702
