简介
A jammed bike lock cannot be used properly, as the key would not be able to properly unlock the bike lock. If your U-Lock bike lock cannot be unlocked due to the fact that it is jammed, use this guide to fix the jam.
Before using the guide, make sure you are using the correct key and inserting it in the correct direction. By doing so, you can confirm if the bike lock is actually jammed.
You will need WD-40 in order to lubricate the lock. You will also need cotton swabs and paper towels to clean the lock. When using WD-40, make sure to exercise caution, as if it gets into your eyes there will be irritation.
你所需要的
Grab the lock and look inside the keyhole located under the lock.
