跳转到主内容
修复你的物品
维修的权力
商店
简介
Do you have a pair of shoes or just one shoe with a hole on the shoe sole? With this guide, you will be able to repair the hole and reuse the shoe rather than buying a new pair.
  1. Scrape off any extra material near the area of the hole that is not part of the outsole of the shoe. Clean the outsole with a wet paper towel. Clean and dry the outsole with a paper towel before starting.
    • Scrape off any extra material near the area of the hole that is not part of the outsole of the shoe.
    • Clean the outsole with a wet paper towel.
    • Clean and dry the outsole with a paper towel before starting.
  2. Use the 120 grit sandpaper to roughen the edges of the hole on the outsole. This helps the shoe goo adhere more readily to the outsole. This helps the shoe goo adhere more readily to the outsole.
    • Use the 120 grit sandpaper to roughen the edges of the hole on the outsole.
    • This helps the shoe goo adhere more readily to the outsole.
  3. Pull the insole out of the shoe. Apply duct tape inside the shoe (on the other side of the hole). Make sure the duct tape covers up the entire hole, so there will be no shoe goo going through the sole into the shoe.
    • Pull the insole out of the shoe.
    • Apply duct tape inside the shoe (on the other side of the hole).
    • Make sure the duct tape covers up the entire hole, so there will be no shoe goo going through the sole into the shoe.
    • For holes that ripped through the shoe sole and to the inside of the shoe, this step is very important.
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. Apply the shoe goo to fill up the hole on the outsole. Apply enough shoe goo to cover up all of the areas of the hole.
    • Apply the shoe goo to fill up the hole on the outsole.
    • Apply enough shoe goo to cover up all of the areas of the hole.
  6. Spread the shoe goo evenly with an ice cube to cover up any uncovered area. The shoe goo will not stick to the ice cube, and you will be able to easily spread the shoe goo. The coldness of the ice also helps the shoe goo set in place. The shoe goo will not stick to the ice cube, and you will be able to easily spread the shoe goo. The coldness of the ice also helps the shoe goo set in place.
    • Spread the shoe goo evenly with an ice cube to cover up any uncovered area.
    • The shoe goo will not stick to the ice cube, and you will be able to easily spread the shoe goo. The coldness of the ice also helps the shoe goo set in place.
  7. Let the shoe sit for 24 hours for the shoe goo to dry.
    • Let the shoe sit for 24 hours for the shoe goo to dry.
    • In this period, do not let any objects come into contact with the glue.
  8. After 24 hours, remove the duct tape from the shoe. Place the insole back into the shoe. Place the insole back into the shoe.
    • After 24 hours, remove the duct tape from the shoe.
    • Place the insole back into the shoe.
  9. Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth. Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth. Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth.
    • Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth.
结论
Now you can walk again!
17等其他人完成本指南。
Wei Zeng
于2015年09月29日注册
677 信誉积分
撰写一个指南
团队
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 的会员
CPSU-GREEN-F15S14G4
5 名成员
创作了12篇指南
Excellent - thank you
Amanda Bowdler - 回复
I used shoe goo on part of the sole that touch the concrete and over about a weeks time it eventually just fell out.
kimdelee - 回复
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
blackwidow - 回复
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
Olga rodriguez - 回复
添加评论
浏览统计数据:
过去的24小时: 203
过去的7天: 1,419
过去的30天: 6,889
总计 145,268
