跳转到主内容
加入维修社区 - 创建账户
How to Repair a Hole in an Ugg Boot
你所需要的
  1. How to Repair a Hole in an Ugg Boot, How to Repair a Hole in an Ugg Boot: 步骤 1 中的图像 1,1
    • Using a sponge, wash the boot with soap and water, then let it dry overnight.
  2. How to Repair a Hole in an Ugg Boot: 步骤 2 中的图像 1,1
    • Make sure there is no fleece sticking out of the boot where the hole is by pushing it in with a pen or pencil.
  3. How to Repair a Hole in an Ugg Boot: 步骤 3 中的图像 1,1
    • Stuff the boot with paper or trash bags so that it holds its shape.
  4. How to Repair a Hole in an Ugg Boot: 步骤 4 中的图像 1,1
    • Using scissors, cut out the size of the suede patch you will need to cover the hole.
  5. How to Repair a Hole in an Ugg Boot: 步骤 5 中的图像 1,1
    • Turn on the iron and set it to silk.
  6. How to Repair a Hole in an Ugg Boot: 步骤 6 中的图像 1,1
    • Put the suede patch over the hole and a shirt over the suede patch.
  7. How to Repair a Hole in an Ugg Boot: 步骤 7 中的图像 1,1
    • Iron the boot for 20 to 30 seconds.
  8. How to Repair a Hole in an Ugg Boot: 步骤 8 中的图像 1,1
    • Using the suede dye, thoroughly saturate the boot.
  9. How to Repair a Hole in an Ugg Boot: 步骤 9 中的图像 1,1
    • Let it fully dry for a day, and then you can wear it.
终点
Giselle Ochoa
于10/25/23注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-15, Kershman Fall 2023 CSU Los Angeles, Team 4-15, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G15
1 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 219
总计 8,978
