跳转到主内容
How to Repair a Hole in an Inflatable Floatie
你所需要的
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 步骤 1 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 步骤 1 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 步骤 1 中的图像 3,3
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: 步骤 2 中的图像 1,2 How to Repair a Hole in an Inflatable Floatie: 步骤 2 中的图像 2,2
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: 步骤 3 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie: 步骤 3 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie: 步骤 3 中的图像 3,3
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: 步骤 4 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie: 步骤 4 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie: 步骤 4 中的图像 3,3
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: 步骤 5 中的图像 1,3 How to Repair a Hole in an Inflatable Floatie: 步骤 5 中的图像 2,3 How to Repair a Hole in an Inflatable Floatie: 步骤 5 中的图像 3,3
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: 步骤 6 中的图像 1,2 How to Repair a Hole in an Inflatable Floatie: 步骤 6 中的图像 2,2
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
结论
Enjoy your renewed floatie!
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 168
