跳转到主内容
How to Repair a Hole in a Therm-a-Rest Sleeping Pad
你所需要的
  1. How to Repair a Hole in a Therm-a-Rest Sleeping Pad, How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 1 中的图像 1,3 How to Repair a Hole in a Therm-a-Rest Sleeping Pad, How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 1 中的图像 2,3 How to Repair a Hole in a Therm-a-Rest Sleeping Pad, How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 1 中的图像 3,3
    • Blow up the sleeping pad full of air using the intake valve in the top left corner.
    • Open the valve by turning it counter-clock-wise.
    • Place your mouth over the valve, and blow air into the pad until is is inflated.
    • With your mouth over the valve, turn the valve clockwise to close it.
  2. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 2 中的图像 1,1
    • Fold the pad in half to increase the air pressure.
  3. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 3 中的图像 1,2 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 3 中的图像 2,2
    • Spray soapy water on the section of the pad where you think the hole is located.
  4. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 4 中的图像 1,2 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 4 中的图像 2,2
    • Look for small bubbles forming on the pad indicating the location of the hole.
    • Mark the hole with a marker.
    • If you cannot locate the hole with the soapy water, fill a bathtub with water, and submerge your pad. Look for small air bubbles escaping from the pad into the water indicating the location of the hole.
  5. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 5 中的图像 1,1
    • Obtain a Therm-a-Rest repair kit including a packet of HotBond Adhesive, patch, and wood stick or similar.
  6. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 6 中的图像 1,2 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 6 中的图像 2,2
    • Boil water in a flat bottomed pan.
    • Heat the HotBond Adhesive packet in the boiling water for three minutes.
    • Carefully remove the HotBond Adhesive from the water with a spoon.
  7. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 7 中的图像 1,2 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 7 中的图像 2,2
    • Tear off the end of the HotBond Adhesive packet.
    • Squeeze the adhesive out of the packet onto the hole in the pad.
    • Spread the adhesive with the wood stick until the adhesive is spread in an even circular layer approximately the size of a dime.
  8. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 8 中的图像 1,3 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 8 中的图像 2,3 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 8 中的图像 3,3
    • Firmly press the patch, shiny side down, onto the HotBond Adhesive on the mattress.
    • Place a layer of plastic, such as a plastic bag, over the patch.
    • Open the intake valve by turning the valve counter-clockwise.
    • Place the pan of hot water on top of the plastic layer and patch for one minute.
  9. How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 9 中的图像 1,2 How to Repair a Hole in a Therm-a-Rest Sleeping Pad: 步骤 9 中的图像 2,2
    • Remove the pan of water, and using a hard cylindrical object, such as a cup, roll over the patch a few times.
    • Allow the patch to set for 10 minutes before use.
结论
This guide can be used to fix similar types of sleeping pads. This patch will help you prolong the life of your camping gear!
2等其他人完成本指南。
Kellie Cochran
于02/24/15注册
184 声望
撰写一个指南
团队
Cal Poly, Team 24-3, Green Winter 2015 Cal Poly, Team 24-3, Green Winter 2015 的会员
CPSU-GREEN-W15S24G3
5 名成员
创作了5篇指南
3条评论
Do I need to deflate the mat before applying the glue?
Kevin Smith - 回复
How does one find a very slow leak? Somehow pressurize the pad to 15 or 20 pounds?
awalter - 回复
You could try submerging the inflated sleeping pad in a bathtub. Keep an eye out for small bubbles and you should find your leak.
Austin Blakely -
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 15
过去 30 天: 51
总计 8,967
