跳转到主内容
How to Repair a Hair Clip with a Detached Spring
你所需要的
  1. How to Repair a Hair Clip with a Detached Spring, How to Repair a Hair Clip with a Detached Spring: 步骤 1 中的图像 1,2 How to Repair a Hair Clip with a Detached Spring, How to Repair a Hair Clip with a Detached Spring: 步骤 1 中的图像 2,2
    • Place the two pieces of the hair clip together.
    • The circles on the top of the clip should align.
  2. How to Repair a Hair Clip with a Detached Spring: 步骤 2 中的图像 1,2 How to Repair a Hair Clip with a Detached Spring: 步骤 2 中的图像 2,2
    • Tie the rubber band around the hair clip to secure the pieces in place.
  3. How to Repair a Hair Clip with a Detached Spring: 步骤 3 中的图像 1,1
    • Insert the pin halfway into the circles on the top of the clip.
  4. How to Repair a Hair Clip with a Detached Spring: 步骤 4 中的图像 1,1
    • Place the spring next to the inserted pin with the two edges facing upwards.
  5. How to Repair a Hair Clip with a Detached Spring: 步骤 5 中的图像 1,1
    • Use the pliers to push the pin through the spring and remaining holes.
  6. How to Repair a Hair Clip with a Detached Spring: 步骤 6 中的图像 1,3 How to Repair a Hair Clip with a Detached Spring: 步骤 6 中的图像 2,3 How to Repair a Hair Clip with a Detached Spring: 步骤 6 中的图像 3,3
    • Take the rubber band off and test the repair.
结论
8等其他人完成本指南。
6指南评论
Where do I get the springs from?
Jessica stone - 回复
Where can I get new pins?
Nancy P. - 回复
Did anyone get answers for the springs and pin questions? Where do we get those?
Julianna Di Miceli - 回复
From Hungary and I found springs for sale in a designated shop online, but they're insanely overpriced. One spring goes for 1.49 in USD for which I can buy a brand new hair clip for... Wild how much they charge for a tiny piece of bent wire!
Georgina - 回复
Me encantooo!!! Si no que no le puse la coleta eso por que mi traba era una flor y me molestabaa!! Gracias por el tutorial, me sirvió mucho...
lucía - 回复
添加评论
浏览统计数据:
过去 24 小时: 69
过去 7 天: 494
过去 30 天: 2,149
总计 96,462
