跳转到主内容
How to Repair a Frayed Headphone Cable
你所需要的
  1. How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: 步骤 1 中的图像 1,2 How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: 步骤 1 中的图像 2,2
    • Cut above the frayed portion of the cable using wire cutters.
    • Using the wire cutters, strip away approximately one inch of wire coating.
    • Use caution to avoid cutting too far into the wire.
  2. How to Repair a Frayed Headphone Cable: 步骤 2 中的图像 1,2 How to Repair a Frayed Headphone Cable: 步骤 2 中的图像 2,2
    • After stripping the wire, four wires should be exposed. The wires should be three different colors.
    • Red: Right channel
    • Gold/copper: Ground
    • Blue/green: Left channel
    • Twist the two ground wires together.
  3. How to Repair a Frayed Headphone Cable: 步骤 3 中的图像 1,2 How to Repair a Frayed Headphone Cable: 步骤 3 中的图像 2,2
    • Unscrew the plug housing.
    • Thread the wire through the plug housing.
  4. How to Repair a Frayed Headphone Cable: 步骤 4 中的图像 1,1
    • Remove the enamel from the red and blue wires with a wire stripper.
  5. How to Repair a Frayed Headphone Cable: 步骤 5 中的图像 1,1
    • With a soldering iron, apply a small amount of solder to the end of each wire.
    • This is especially important for the twisted ground wires; the solder should hold them together.
  6. How to Repair a Frayed Headphone Cable: 步骤 6 中的图像 1,3 How to Repair a Frayed Headphone Cable: 步骤 6 中的图像 2,3 How to Repair a Frayed Headphone Cable: 步骤 6 中的图像 3,3
    • Thread the wires through each hole and wrap them back over.
    • See the third picture for a diagram of where each wire goes.
    • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
  7. How to Repair a Frayed Headphone Cable: 步骤 7 中的图像 1,2 How to Repair a Frayed Headphone Cable: 步骤 7 中的图像 2,2
    • Solder over each lead's hole, connecting the wire to the lead.
    • Your solder joints should completely cover the hole and surround the wire.
    • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
  8. How to Repair a Frayed Headphone Cable: 步骤 8 中的图像 1,1
    • Screw the housing back onto the jack and test your work.
    • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
终点
36等其他人完成本指南。
Tyler
于02/24/15注册
841 声望
撰写一个指南
团队
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015 的会员
CPSU-GREEN-W15S23G2
4 名成员
创作了17篇指南
2条评论
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - 回复
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 134
过去 30 天: 609
总计 114,608
