跳转到主内容
How to Repair a Fastmark by AMT Datasouth Wristband Printer
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. How to Repair a Fastmark by AMT Datasouth Wristband Printer, How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 1 中的图像 1,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer, How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 1 中的图像 2,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer, How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 1 中的图像 3,3
    • Open the machine by lifting the right side up.
  2. How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 2 中的图像 1,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 2 中的图像 2,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 2 中的图像 3,3
    • Assess where the problem is within the machine. Press the green button that says "push" to release the end of the armband that is clamped in the machine.
  3. How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 3 中的图像 1,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 3 中的图像 2,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 3 中的图像 3,3
    • Slide the green bar to the right then pull it down to remove the roll of armbands.
  4. How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 4 中的图像 1,1
    • Remove the armband strip from under the press.
  5. How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 5 中的图像 1,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 5 中的图像 2,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 5 中的图像 3,3
    • Replace the previous armband roll if it's damaged and insert a new roll by sliding it onto the device and pushing the green bar back into place.
  6. How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 6 中的图像 1,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 6 中的图像 2,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 6 中的图像 3,3
    • Weave the new armband strip under the back and green cylinder and through the press. Close the press by pushing it down firmly.
  7. How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 7 中的图像 1,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 7 中的图像 2,3 How to Repair a Fastmark by AMT Datasouth Wristband Printer: 步骤 7 中的图像 3,3
    • Close the top of the armband machine and then press the feed button on the outside to make sure it is working correctly.
结论
Repeat these steps if the text is not lined up in the correct place on the armband.
2等其他人完成本指南。
Devon Sineno
于02/02/20注册
202 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,156
