跳转到主内容
How to Repair a Dangle Earring
你所需要的
  1. How to Repair a Dangle Earring, How to Repair a Dangle Earring: 步骤 1 中的图像 1,1
    • Clean the jump ring of the earring and the earring itself.
    • This step is optional.
  2. How to Repair a Dangle Earring: 步骤 2 中的图像 1,2 How to Repair a Dangle Earring: 步骤 2 中的图像 2,2
    • Take the jump ring with the two small needle-nose pliers.
    • Gently open the jump ring using the needle nose pliers.
  3. How to Repair a Dangle Earring: 步骤 3 中的图像 1,2 How to Repair a Dangle Earring: 步骤 3 中的图像 2,2
    • Take the top part of the earring with your dominant hand.
    • Put the jump ring through the top part of the earring.
    • You can hold the jump ring with a small needle-nose pliers with your non-dominant hand.
  4. How to Repair a Dangle Earring: 步骤 4 中的图像 1,2 How to Repair a Dangle Earring: 步骤 4 中的图像 2,2
    • Pass the earring through the opening of the jump ring.
    • Make sure that both parts of the earring face the same direction.
  5. How to Repair a Dangle Earring: 步骤 5 中的图像 1,2 How to Repair a Dangle Earring: 步骤 5 中的图像 2,2
    • To close the jump ring, use both of the needle nose pliers.
    • Use your dominant hand to close the space in the jump ring.
    • Try to keep your non-dominant hand still.
  6. How to Repair a Dangle Earring: 步骤 6 中的图像 1,2 How to Repair a Dangle Earring: 步骤 6 中的图像 2,2
    • Make sure that the jump ring is closed.
    • Hold the earring up to make sure it's secure.
结论
To just change a clasp that it was not broken, follow these instructions in reverse order.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 1,568
