跳转到主内容
How to Repair a Damaged Steelcase Cachet Chair Armrest
你所需要的
  1. How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 1 中的图像 1,3 How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 1 中的图像 2,3 How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 1 中的图像 3,3
    • Use an iFixit Opening Tool to remove the broken piece from your cracked armrest.
    • Avoid the jagged edges of plastic as they are sharp and could cut or scrape the skin.
  2. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 2 中的图像 1,2 How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 2 中的图像 2,2
    • Use sandpaper to lightly sand the edges of the broken piece of arm rest.
    • Remove any remaining debris from the armrest.
  3. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 3 中的图像 1,2 How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 3 中的图像 2,2
    • Wear gloves! The putty is toxic!
    • Cut or pull off a small section of putty.
    • Knead the putty in your hands for 30-60 seconds until it is a uniform color.
  4. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 4 中的图像 1,1
    • Work quickly! The putty will begin to harden in 5 minutes!
    • Apply a small amount of putty on the inside of the hollow space of the armrest.
    • The putty will act as a support for the broken piece.
    • Repeat Step 3 to use as many pieces of putty as needed.
  5. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 5 中的图像 1,1
    • Apply putty along the edges of the broken piece.
  6. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 6 中的图像 1,2 How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 6 中的图像 2,2
    • Set the broken piece back onto the armrest.
    • Try to make the broken piece level with the rest of the armrest, as this will make Steps 7 & 8 easier.
    • Let the putty dry for about 10 minutes.
  7. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 7 中的图像 1,2 How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 7 中的图像 2,2
    • Apply the plastic putty over the broken piece.
    • Press putty into any remaining empty spaces.
    • Repeat Step 3 as many times as needed.
    • Let the putty dry for 10 minutes in between applications.
  8. How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 8 中的图像 1,2 How to Repair a Damaged Steelcase Cachet Chair Armrest: 步骤 8 中的图像 2,2
    • Sand down the putty covering to make the surface smooth and level with the armrest.
    • Paint-match the color of the chair and paint over the putty for a cosmetically seamless result.
终点
2等其他人完成本指南。
Henry Xu
于04/26/24注册
169 声望
撰写一个指南
团队
UC Davis, Team 4-5, Whithaus Spring 2024 UC Davis, Team 4-5, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S4G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 27
总计 84
