跳转到主内容
How to Repair a Damaged Apple USB Cable
你所需要的
  1. How to Repair a Damaged Apple USB Cable, Wire: 步骤 1 中的图像 1,1
    • Identify the short in the wire and cut the damaged portion of the USB cable with the help of scissors.
    • Using scissors, remove the outer insulation of wire, unwrap and separate the core wiring from the shielding.
    • Hold the scissors close and roll the wire between the scissors to prevent damage of core wiring.
  2. How to Repair a Damaged Apple USB Cable: 步骤 3 中的图像 1,1
    • Separate the red, green, black and white wires.
    • Repeat the same procedure on the other half of the USB cable.
  3. How to Repair a Damaged Apple USB Cable: 步骤 4 中的图像 1,3 How to Repair a Damaged Apple USB Cable: 步骤 4 中的图像 2,3 How to Repair a Damaged Apple USB Cable: 步骤 4 中的图像 3,3
    • Once the wires are separated, insert each set of wires deep into four different 3M scotchloks.
    • Thread them through the metal portion.
    • Lock the wires by popping the button.
    • Popping the button might seem tedious. To make it easy, place the button between scissors handle to apply pressure at a focussed point to lock it.
    • Do a slide test to see if the wires are locked and if your guide is successful.
结论
The best way to repair your USB cable, without any complicated soldering technique and this procedure is very economical.
2等其他人完成本指南。
团队
一条评论
ありがとう❗️助かりました。
竹田卓朗 - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 85
过去 30 天: 476
总计 8,528
