跳转到主内容
How to Repair a Damaged Action Figure
你所需要的
  1. How to Repair a Damaged Action Figure, How to Repair a Damaged Action Figure: 步骤 1 中的图像 1,1
    • Clean the figurine and wash your hands before starting.
  2. How to Repair a Damaged Action Figure: 步骤 2 中的图像 1,1
    • Identify the broken parts and apply a small drop of super glue on the area needing a fix.
    • CAUTION: AVOID DIRECT SKIN CONTACT WITH THE GLUE. Glue can cause skin irritation or burns.
  3. How to Repair a Damaged Action Figure: 步骤 3 中的图像 1,2 How to Repair a Damaged Action Figure: 步骤 3 中的图像 2,2
    • Press the two pieces together and make sure they match. Hold them together tightly for 2 minutes.
    • If any glue leaks outside when pressing, use an alcohol wipe to clean it.
  4. How to Repair a Damaged Action Figure: 步骤 4 中的图像 1,1
    • Let the glue settle and dry for a minimum of 1 hour.
  5. How to Repair a Damaged Action Figure: 步骤 5 中的图像 1,1
    • Use acrylic paint as necessary for patching chipped sections of the plastic.
  6. How to Repair a Damaged Action Figure: 步骤 6 中的图像 1,1
    • Allow the paint to fully dry before attempting to move or adjust the figurine.
    • You can use hair dryer to speed up the drying process.
结论
另外一个人完成了本指南。
Anabela Stewart
于01/31/23注册
142 声望
撰写一个指南
团队
UC Davis, Team 3-8, Andersen Winter 2023 UC Davis, Team 3-8, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S3G8
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 89
总计 3,187
