跳转到主内容
How to Repair a Crack on a Vittorazi Moster Exhaust
你所需要的
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 1 中的图像 1,3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 1 中的图像 2,3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 1 中的图像 3,3
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 5 中的图像 1,2 How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 5 中的图像 2,2
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 6 中的图像 1,1
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 7 中的图像 1,1
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 8 中的图像 1,2 How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 8 中的图像 2,2
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 9 中的图像 1,2 How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 9 中的图像 2,2
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 10 中的图像 1,2 How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 10 中的图像 2,2
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: 步骤 11 中的图像 1,1
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 1,067
