跳转到主内容
How to Repair a Christmas Tree Light Wire
你所需要的
  1. How to Repair a Christmas Tree Light Wire, How to Repair a Christmas Tree Light Wire: 步骤 1 中的图像 1,1
    • Unplug the lighting.
  2. How to Repair a Christmas Tree Light Wire: 步骤 2 中的图像 1,2 How to Repair a Christmas Tree Light Wire: 步骤 2 中的图像 2,2
    • Using the wire strippers, split both wires apart approximately one inch.
  3. How to Repair a Christmas Tree Light Wire: 步骤 3 中的图像 1,2 How to Repair a Christmas Tree Light Wire: 步骤 3 中的图像 2,2
    • Using the wire strippers, strip about an inch of insulation off of each wire.
    • Use appropriate wire gauge when stripping. A good practice is to start with large gauge and work your way down.
  4. How to Repair a Christmas Tree Light Wire: 步骤 4 中的图像 1,2 How to Repair a Christmas Tree Light Wire: 步骤 4 中的图像 2,2
    • Twist all four copper strands.
    • This will make it easier to work with and help prevent fraying.
  5. How to Repair a Christmas Tree Light Wire: 步骤 5 中的图像 1,1
    • Insert the heat shrink tubing on the longer end of your wire.
    • Once the heat shrink is on your wire, slide it out of your way. We will address the heat shrink in Step 9.
  6. How to Repair a Christmas Tree Light Wire: 步骤 6 中的图像 1,3 How to Repair a Christmas Tree Light Wire: 步骤 6 中的图像 2,3 How to Repair a Christmas Tree Light Wire: 步骤 6 中的图像 3,3
    • Cross and twist the wires together to create a connection.
    • This helps the wires form a better connection when soldering together.
  7. How to Repair a Christmas Tree Light Wire: 步骤 7 中的图像 1,2 How to Repair a Christmas Tree Light Wire: 步骤 7 中的图像 2,2
    • Solder your wires together by applying heat to the bottom of your wires and solder to the top. The solder will melt onto the copper strands solidifying both wires together.
    • Burn and fire hazard. Take appropriate precautions and solder in a well-ventilated area.
    • Pre-heat soldering iron to 325 Fahrenheit.
  8. How to Repair a Christmas Tree Light Wire: 步骤 8 中的图像 1,1
    • Use electrical tape to wrap the soldered wires.
    • This will prevent both wires from contacting each other.
  9. How to Repair a Christmas Tree Light Wire: 步骤 9 中的图像 1,1
    • Slide the heat shrink over the soldered wires.
  10. How to Repair a Christmas Tree Light Wire: 步骤 10 中的图像 1,1
    • Use your heat source to apply heat to the heat shrink.
    • Apply heat from heat appliance half an inch away from heat shrink.
  11. How to Repair a Christmas Tree Light Wire: 步骤 11 中的图像 1,2 How to Repair a Christmas Tree Light Wire: 步骤 11 中的图像 2,2
    • Connect your Christmas tree plug into the outlet.
结论
You've completed soldering and properly covered any exposed wires being worked on. Connect your cable to an electrical outlet; you're Christmas tree is ready to light once again.
Javi Becerra
于03/01/23注册
199 声望
撰写一个指南
1指南评论
You can also offset the lengths of the twin wires so the joints aren't next to each other for more protection from a short.
pdb - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 88
过去 30 天: 322
总计 1,855
