跳转到主内容
加入维修社区 - 创建账户
How to Repair a Chip in Laminate Flooring
你所需要的
  1. How to Repair a Chip in Laminate Flooring, How to Repair a Chip in Laminate Flooring: 步骤 1 中的图像 1,1
    • Wipe the chipped area with a damp cloth to remove dust and debris.
    • A clean surface helps the repair compound adhere better and ensures a smoother finish.
    询问修复机器人
    添加评论
  2. How to Repair a Chip in Laminate Flooring: 步骤 2 中的图像 1,3 How to Repair a Chip in Laminate Flooring: 步骤 2 中的图像 2,3 How to Repair a Chip in Laminate Flooring: 步骤 2 中的图像 3,3
    • Use a knife to cut off enough wood putty to completely fill the chipped area.
    询问修复机器人
    添加评论
  3. How to Repair a Chip in Laminate Flooring: 步骤 3 中的图像 1,2 How to Repair a Chip in Laminate Flooring: 步骤 3 中的图像 2,2
    • Knead the putty for 2 minutes until it reaches a smooth and consistent texture.
    询问修复机器人
    添加评论
  4. How to Repair a Chip in Laminate Flooring: 步骤 4 中的图像 1,2 How to Repair a Chip in Laminate Flooring: 步骤 4 中的图像 2,2
    • Press the putty firmly and evenly to fill the chipped area.
    询问修复机器人
    添加评论
  5. How to Repair a Chip in Laminate Flooring: 步骤 5 中的图像 1,2 How to Repair a Chip in Laminate Flooring: 步骤 5 中的图像 2,2
    • Use a damp cloth to smooth the area before the putty hardens.
    • Allow the putty to set for 30–60 minutes before continuing to the next step.
    询问修复机器人
    添加评论
  6. How to Repair a Chip in Laminate Flooring: 步骤 6 中的图像 1,2 How to Repair a Chip in Laminate Flooring: 步骤 6 中的图像 2,2
    • Prepare matching color repair compound in a small container.
    询问修复机器人
    添加评论
  7. How to Repair a Chip in Laminate Flooring: 步骤 7 中的图像 1,2 How to Repair a Chip in Laminate Flooring: 步骤 7 中的图像 2,2
    • Apply the color to the repaired area with a brush and spread it evenly for full coverage.
    • Use gentle, precise brush strokes to blend the repair naturally with the surrounding flooring.
    询问修复机器人
    添加评论
  8. How to Repair a Chip in Laminate Flooring: 步骤 8 中的图像 1,2 How to Repair a Chip in Laminate Flooring: 步骤 8 中的图像 2,2
    • Clean the area around the repair to remove excess material and ensure a polished finish.
    • Allow the area to dry for 6–12 hours before walking on it or making any touchups.
    询问修复机器人
    添加评论
结论
Repairing chips in laminate flooring doesn’t have to be hard or costly. With minimal effort, this repaired flooring looks renewed, lasts longer, and provides a practical solution for everyday wear and tear.
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 159
总计 1,518
