跳转到主内容
How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822
你所需要的
  1. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822, How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 1 中的图像 1,3 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822, How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 1 中的图像 2,3 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822, How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 1 中的图像 3,3
    • Use your fingers to pull the top of the speaker grill away from the speaker enclosure.
    • Pull the bottom of the grill away from the speaker enclosure and then completely remove the grill.
    • Four posts attach the grill assembly to the front of speaker enclosure. These posts are located on the back side of the grill assembly.
  2. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 2 中的图像 1,2 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 2 中的图像 2,2
    • Remove the top two 9.5 mm Phillips #1 screws from the speaker.
    • Remove the two 9.5 mm Phillips #1 screws located below the speaker screws.
    • Slowly work your way around the seam until the two parts of the enclosure are free.
    • More speaker cable slack may be achieved by pulling additional cable through the rear of the case.
  3. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 3 中的图像 1,2 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 3 中的图像 2,2
    • Inspect both sides of the printed circuit board (PCB) for any raised traces, off-colored areas, or loose components.
    • This step is to avoid making a mechanical repair (re-soldering the wires to the PCB) on a piece of equipment that also has obvious electrical or mechanical issues.
  4. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 4 中的图像 1,1
    • Use desoldering braid and a soldering iron to wick away the old solder and wire remnants from the solder pads and through-holes.
    • Do not leave solder bridges across the pads as this will cause functional issues.
  5. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 5 中的图像 1,2 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 5 中的图像 2,2
    • Use wire strippers to remove a small section of insulation from the wires.
    • Use a soldering iron and solder to tin the wires. This prevents the strands from fraying.
  6. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 6 中的图像 1,2 How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 6 中的图像 2,2
    • Insert the yellow wire into the through-hole marked "R".
    • Insert the bare ground wire into the through-hole marked "G".
    • Insert the white wire into the through-hole marked "L".
  7. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 7 中的图像 1,1
    • Use the soldering iron to flow solder between each wire and its solder pad.
  8. How to Repair a Broken Speaker Cable on a Harman Kardon CN-04N567-4822: 步骤 8 中的图像 1,1
    • Reassemble the two parts of the enclosure making sure that the PCB-mounted audio jacks are lined up with the mating holes of the rear enclosure.
    • Route the cable inside the enclosure to avoid stressing the solder joints.
结论
8等其他人完成本指南。
Ken Gage
于06/09/16注册
306 声望
撰写一个指南
团队
Texas Tech, Team 3-1, Rauch SU 2016 Texas Tech, Team 3-1, Rauch SU 2016 的会员
TTU-RAUCH-SU16S3G1
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 67
总计 4,344
