跳转到主内容
How to Repair a Broken Slider on a Suitcase Zipper
你所需要的
  1. How to Repair a Broken Slider on a Suitcase Zipper, Slider on a Zipper: 步骤 1 中的图像 1,1
    • Locate the zipper with the broken slider on the suitcase.
  2. How to Repair a Broken Slider on a Suitcase Zipper: 步骤 2 中的图像 1,2 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 2 中的图像 2,2
    • Find the top of the zipper and locate the two stop pieces.
  3. How to Repair a Broken Slider on a Suitcase Zipper: 步骤 3 中的图像 1,2 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 3 中的图像 2,2
    • Use your pliers to remove both of the stop pieces from the zipper.
    • Be careful to not tear the zipper fabric when removing the stop pieces.
  4. How to Repair a Broken Slider on a Suitcase Zipper: 步骤 4 中的图像 1,3 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 4 中的图像 2,3 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 4 中的图像 3,3
    • Remove the original slider from the zipper.
  5. How to Repair a Broken Slider on a Suitcase Zipper: 步骤 5 中的图像 1,2 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 5 中的图像 2,2
    • Attach the new slider to the zipper.
    • You may need to use some force to get the new zipper slider onto the zipper itself.
  6. How to Repair a Broken Slider on a Suitcase Zipper: 步骤 6 中的图像 1,3 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 6 中的图像 2,3 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 6 中的图像 3,3
    • Attach two new stop pieces with a pair of pliers.
    • Use the pliers to crimp the stop pieces into the fabric.
    • The best area to place the stop pieces is directly above the first few teeth of the zipper.
  7. How to Repair a Broken Slider on a Suitcase Zipper: 步骤 7 中的图像 1,2 How to Repair a Broken Slider on a Suitcase Zipper: 步骤 7 中的图像 2,2
    • Check to make sure the zipper works by moving the slider up and down.
终点
Demetria
于03/07/19注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 53
总计 1,320
