简介
If your dangling earring has suddenly fallen apart, making it unwearable, odds are the jump ring has opened a little too far. Although jump rings are made of soft, flexible metal, and fail easily and often, thankfully they're also very easy to repair.
To fix your jump ring, you only need a pair of tools that can be easily found in any hardware or arts-and-crafts store: two needle nose pliers.
As jump rings are very small, we recommend working in a well lit area.
你所需要的
Firmly grasp the broken jump ring using one set of small needle-nose pliers.
即将完成!
Your earrings are ready to be worn again!
结论
