跳转到主内容
How to Repair a Broken Jump Ring
你所需要的
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: 步骤 1 中的图像 1,1
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: 步骤 2 中的图像 1,1
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: 步骤 3 中的图像 1,1
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: 步骤 4 中的图像 1,2 How to Repair a Broken Jump Ring: 步骤 4 中的图像 2,2
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: 步骤 5 中的图像 1,2 How to Repair a Broken Jump Ring: 步骤 5 中的图像 2,2
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: 步骤 6 中的图像 1,2 How to Repair a Broken Jump Ring: 步骤 6 中的图像 2,2
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
结论
Your earrings are ready to be worn again!
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 36
总计 1,030
