跳转到主内容
How to Repair a Broken Huggie Earring Clasp
你所需要的
  1. How to Repair a Broken Huggie Earring Clasp, How to Repair a Broken Huggie Earring Clasp: 步骤 1 中的图像 1,1
    • Clean the post and clasp of the earring with a dry cloth.
  2. How to Repair a Broken Huggie Earring Clasp: 步骤 2 中的图像 1,2 How to Repair a Broken Huggie Earring Clasp: 步骤 2 中的图像 2,2
    • Close the earring and note where the main post hits the notch on the opposite side.
    • There are two notches, one on the main post and one on the opposite side of the earring.
  3. How to Repair a Broken Huggie Earring Clasp: 步骤 3 中的图像 1,1
    • Mark this spot with a writing instrument (optional).
  4. How to Repair a Broken Huggie Earring Clasp: 步骤 4 中的图像 1,1
    • Re-open the earring.
  5. How to Repair a Broken Huggie Earring Clasp: 步骤 5 中的图像 1,3 How to Repair a Broken Huggie Earring Clasp: 步骤 5 中的图像 2,3 How to Repair a Broken Huggie Earring Clasp: 步骤 5 中的图像 3,3
    • Ensure the post is lined up with the opposite notch. If not, gently bend it with your finger until it is in a suitable position.
  6. How to Repair a Broken Huggie Earring Clasp: 步骤 6 中的图像 1,1
    • Grip the earring post with a small plier or tweezer and push the post slightly upward.
  7. How to Repair a Broken Huggie Earring Clasp: 步骤 7 中的图像 1,2 How to Repair a Broken Huggie Earring Clasp: 步骤 7 中的图像 2,2
    • Open to check if the earring clicks.
  8. How to Repair a Broken Huggie Earring Clasp: 步骤 8 中的图像 1,1
    • If the earring isn’t clicking, push the post further upward using pliers.
    • Adjust, then check again.
  9. How to Repair a Broken Huggie Earring Clasp: 步骤 9 中的图像 1,1
    • If the earring clicks but is hard to open, push the post downward using pliers.
    • This is an adjustment process, so make small adjustments until it is restored.
  10. How to Repair a Broken Huggie Earring Clasp: 步骤 10 中的图像 1,1
    • Make final adjustments until the huggie clasp clicks and the earring closes securely.
    • Wipe the marker off of your earring.
结论
Your earring is now fixed! If the post bends again, repeat the same steps to repair.
Hana Ito
于04/26/24注册
181 声望
撰写一个指南
团队
UC Davis, Team 4-6, Whithaus Spring 2024 UC Davis, Team 4-6, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S4G6
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 18
总计 58
