简介
If your backpack's drawstring is loose and the closing mechanism isn't working as it should, don't worry! We've got you covered. In just a few simple steps, we'll show you how to repair the string and make your favourite backpack as secure and comfortable as it used to be!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
你所需要的
Cut away any damaged threads around the drawstring tunnel, to create a clean surface to repair.
Place the drawstring inside the tunnel.
Turn the edges inside, so that the drawstring is tucked inside.
Pin the folded parts of the tunnel securely in place and prepare the sewing machine.
Tip: For tips on setting up the machine take a look at this iFixit guide.
Depress the sewing machine foot and remove any pins in the way of the sewing route.
Start sewing a straight line from one side to the other and add a lock stitch at the beginning and the end.
Finish the sewing and cut the loose thread to make a neat finish.
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
- Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
- Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
- Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
