跳转到主内容
How to Repair a Broken Drawstring Tunnel in a Backpack
你所需要的
  1. How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: 步骤 1 中的图像 1,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: 步骤 1 中的图像 2,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: 步骤 1 中的图像 3,3
    • Identify the defective area and assess how large the damage is.
  2. How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: 步骤 2 中的图像 1,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: 步骤 2 中的图像 2,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: 步骤 2 中的图像 3,3
    • Cut away any damaged threads around the drawstring tunnel, to create a clean surface to repair.
  3. How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: 步骤 3 中的图像 1,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: 步骤 3 中的图像 2,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: 步骤 3 中的图像 3,3
    • Place the drawstring inside the tunnel.
    • Turn the edges inside, so that the drawstring is tucked inside.
  4. How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: 步骤 4 中的图像 1,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: 步骤 4 中的图像 2,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: 步骤 4 中的图像 3,3
    • Pin the folded parts of the tunnel securely in place and prepare the sewing machine.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Depress the sewing machine foot and remove any pins in the way of the sewing route.
  5. How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: 步骤 5 中的图像 1,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: 步骤 5 中的图像 2,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: 步骤 5 中的图像 3,3
    • Start sewing a straight line from one side to the other and add a lock stitch at the beginning and the end.
    • Finish the sewing and cut the loose thread to make a neat finish.
  6. How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: 步骤 6 中的图像 1,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: 步骤 6 中的图像 2,3 How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: 步骤 6 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 39
总计 429
