跳转到主内容
How to Repair a Broken Cabinet
你所需要的
  1. How to Repair a Broken Cabinet, How to Repair a Broken Cabinet: 步骤 1 中的图像 1,1
    • This is the broken dresser drawer, duct tape & 5 minute 2 part wood epoxy.
  2. How to Repair a Broken Cabinet: 步骤 2 中的图像 1,2 How to Repair a Broken Cabinet: 步骤 2 中的图像 2,2
    • Take a piece of duct tape and put it on both sides for extra bonding support. Only put the tape on the bigger part of the dresser door for now. You will attach the other side with tape in a later step.
  3. How to Repair a Broken Cabinet: 步骤 3 中的图像 1,3 How to Repair a Broken Cabinet: 步骤 3 中的图像 2,3 How to Repair a Broken Cabinet: 步骤 3 中的图像 3,3
    • This is a 5 minute quick setting 2 part wood epoxy. Take the top off the epoxy. Connect the syringe tip and lock it in place. Press the plunger so you can fill the needle tip with epoxy.
  4. How to Repair a Broken Cabinet: 步骤 4 中的图像 1,3 How to Repair a Broken Cabinet: 步骤 4 中的图像 2,3 How to Repair a Broken Cabinet: 步骤 4 中的图像 3,3
    • Run a thick bead of epoxy on the inside rim of the cabinet from one end to the other.
  5. How to Repair a Broken Cabinet: 步骤 5 中的图像 1,1
    • Run a thick bead of epoxy on the inside rim of the smaller piece of cabinet door.
  6. How to Repair a Broken Cabinet: 步骤 6 中的图像 1,3 How to Repair a Broken Cabinet: 步骤 6 中的图像 2,3 How to Repair a Broken Cabinet: 步骤 6 中的图像 3,3
    • Attach and align the smaller cabinet door section to the bigger cabinet door section. Press them firmly together and apply the duct tape on both ends for bonding support.
  7. How to Repair a Broken Cabinet: 步骤 7 中的图像 1,3 How to Repair a Broken Cabinet: 步骤 7 中的图像 2,3 How to Repair a Broken Cabinet: 步骤 7 中的图像 3,3
    • Flip door over to front side and tape both ends of the cabinet. This will add more support while it is drying.
  8. How to Repair a Broken Cabinet: 步骤 8 中的图像 1,3 How to Repair a Broken Cabinet: 步骤 8 中的图像 2,3 How to Repair a Broken Cabinet: 步骤 8 中的图像 3,3
    • After at least 15 minutes you can pull tape off completely and wipe away any excess epoxy. It is now finished and ready to be re-installed back to the cabinet.
结论
3等其他人完成本指南。
Calvesta Walk
于02/07/16注册
254 声望
撰写一个指南
团队
Pasco Hernando, Team 5-8, Prince Winter 2016 Pasco Hernando, Team 5-8, Prince Winter 2016 的会员
PHSC-PRINCE-W16S5G8
1 名成员
创作了1篇指南
一条评论
Lifesaver brother!
Doug Gray - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 70
过去 30 天: 249
总计 22,686
