简介
If you accidentally break your beautiful 3-wick candle and cannot burn it because the jar is heavily damaged. then this guide is for you. This guide will help you save money from buying a new candle and protect the environment from chemical reactions that candle wax causes in the landfill.
This guide requires you to use your stove to melt the candle (from Step 3 to Step 5). Use oven mitts or potholders to handle the cooking pot after it has been heated.
你所需要的
Cut the candle wax into small cubes and remove the wicks.
即将完成!
终点
另外一个人完成了本指南。
