跳转到主内容
How to Repair a Belt Loop on Dress Pants
你所需要的
  1. How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: 步骤 1 中的图像 1,3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: 步骤 1 中的图像 2,3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: 步骤 1 中的图像 3,3
    • Thread the sewing machine with a thread that matches your pants.
    • Thread via your sewing machine instructions. They can be marked on your machine, or in a separate pamphlet.
  2. How to Repair a Belt Loop on Dress Pants: 步骤 2 中的图像 1,3 How to Repair a Belt Loop on Dress Pants: 步骤 2 中的图像 2,3 How to Repair a Belt Loop on Dress Pants: 步骤 2 中的图像 3,3
    • Remove the extension table from the sewing machine.
  3. How to Repair a Belt Loop on Dress Pants: 步骤 3 中的图像 1,1
    • Pin the belt loop seam side up so that the top of the loop is 1/4 inch above the seam.
  4. How to Repair a Belt Loop on Dress Pants: 步骤 4 中的图像 1,3 How to Repair a Belt Loop on Dress Pants: 步骤 4 中的图像 2,3 How to Repair a Belt Loop on Dress Pants: 步骤 4 中的图像 3,3
    • Sew using a straight stitch along the seam.
    • Use the reverse feature on the sewing machine to go over the stitches three times.
    • Once the sewing foot is down and the needle is in the fabric you can remove the pin.
  5. How to Repair a Belt Loop on Dress Pants: 步骤 5 中的图像 1,3 How to Repair a Belt Loop on Dress Pants: 步骤 5 中的图像 2,3 How to Repair a Belt Loop on Dress Pants: 步骤 5 中的图像 3,3
    • Remove the pants from the sewing machine by cutting the threads.
  6. How to Repair a Belt Loop on Dress Pants: 步骤 6 中的图像 1,1
    • Fold the interfacing over so that it is out of the way of the needle.
    • If the pants do not have interfacing, this step can be skipped.
  7. How to Repair a Belt Loop on Dress Pants: 步骤 7 中的图像 1,2 How to Repair a Belt Loop on Dress Pants: 步骤 7 中的图像 2,2
    • Sew the belt loop a 1/4 inch below the seam using a straight stitch.
    • Use the reverse feature to go over the stitches three times.
  8. How to Repair a Belt Loop on Dress Pants: 步骤 8 中的图像 1,1
  9. How to Repair a Belt Loop on Dress Pants: 步骤 9 中的图像 1,1
    • Fold the belt loop over.
  10. How to Repair a Belt Loop on Dress Pants: 步骤 10 中的图像 1,3 How to Repair a Belt Loop on Dress Pants: 步骤 10 中的图像 2,3 How to Repair a Belt Loop on Dress Pants: 步骤 10 中的图像 3,3
    • Trim the belt loop's excess length so that there is a 1/4 inch overlap.
  11. How to Repair a Belt Loop on Dress Pants: 步骤 11 中的图像 1,1
    • Pin the folded belt loop to the top of the waistband.
  12. How to Repair a Belt Loop on Dress Pants: 步骤 12 中的图像 1,2 How to Repair a Belt Loop on Dress Pants: 步骤 12 中的图像 2,2
    • Sew the top of the belt loop with an 1/8 inch seam allowance, using a straight stitch.
    • Use the reverse feature on the sewing machine and go over the stitches three times.
  13. How to Repair a Belt Loop on Dress Pants: 步骤 13 中的图像 1,3 How to Repair a Belt Loop on Dress Pants: 步骤 13 中的图像 2,3 How to Repair a Belt Loop on Dress Pants: 步骤 13 中的图像 3,3
  14. How to Repair a Belt Loop on Dress Pants: 步骤 14 中的图像 1,1
    • Trim any remaining threads.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 5
过去 30 天: 26
总计 52
