跳转到主内容
加入维修社区 - 创建账户
How to Repair a Basketball Leak
你所需要的
    1. How to Repair a Basketball Leak, How to Repair a Basketball Leak: 步骤 1 中的图像 1,3 How to Repair a Basketball Leak, How to Repair a Basketball Leak: 步骤 1 中的图像 2,3 How to Repair a Basketball Leak, How to Repair a Basketball Leak: 步骤 1 中的图像 3,3
      • Locate the leak on the basketball's surface by using one of two methods: the water test or the acoustic test.
      • For the water test, fill a bucket with water, submerge the basketball in the water, and look for bubbles.
      • For the acoustic test, inflate the basketball, hold the ball close to your ear, rotate the ball, and listen for any quiet whistling.
      • The bubbles or quiet whistling noise indicate where air is escaping on the basketball and, therefore, where a leak may be.
      询问修复机器人
      添加评论
    2. How to Repair a Basketball Leak: 步骤 2 中的图像 1,1
      • Once you have found the leak, mark it by placing a small strip of colored tape next to it on the surface of the ball.
      询问修复机器人
      添加评论
    3. How to Repair a Basketball Leak: 步骤 3 中的图像 1,2 How to Repair a Basketball Leak: 步骤 3 中的图像 2,2
      • Clean the leak area of dirt and debris with a clean sponge, soap, and water.
      询问修复机器人
      添加评论
    4. How to Repair a Basketball Leak: 步骤 4 中的图像 1,1
      • Deflate the ball by 20% of the air it currently contains by placing the inflation needle from the ball pump into the inflation hole of the ball until air is released.
      • This will make it easier to place the patch on the ball as it will prevent an excessive amount of air from drying the glue too quickly on the leak area.
      询问修复机器人
      添加评论
    5. How to Repair a Basketball Leak: 步骤 5 中的图像 1,3 How to Repair a Basketball Leak: 步骤 5 中的图像 2,3 How to Repair a Basketball Leak: 步骤 5 中的图像 3,3
      • Use your Slime Tube Patch Kit in the following 4 steps:
      • Take the metal scuffer and sand the leak area.
      • One side of the metal scuffer is very sharp. Be careful to hold the ball so that your fingers are away from the leak area or you could be cut.
      • Apply a thin layer of rubber cement to cover 1 centimeter wider in diameter than the leak area.
      • Place the appropriate sized patch over the whole leak area and gently press it onto the ball's surface.
      • Wait 1 hour for the adhesive to fully dry.
      询问修复机器人
      添加评论
    6. How to Repair a Basketball Leak: 步骤 6 中的图像 1,2 How to Repair a Basketball Leak: 步骤 6 中的图像 2,2
      • Reinflate the basketball.
      询问修复机器人
      添加评论
结论
Test your ball to see if the leak has been repaired. If the ball still loses air in a short amount of time, there may be more leaks. Repeat this process to locate and fix them.
取消:我没有完成这个指南。
Eden Love
于03/07/25注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 57
过去 30 天: 305
总计 3,251
