跳转到主内容
How to Repair a Cabinet Door Knob
你所需要的
  1. How to Repair a  Cabinet Door Knob, How to Repair a  Cabinet Door Knob: 步骤 1 中的图像 1,3 How to Repair a  Cabinet Door Knob, How to Repair a  Cabinet Door Knob: 步骤 1 中的图像 2,3 How to Repair a  Cabinet Door Knob, How to Repair a  Cabinet Door Knob: 步骤 1 中的图像 3,3
    • Unscrew the loose knob from the inside of the cabinet. Turn the Phillips head screwdriver counterclockwise. Look to see if the screw is too short; you should be able to see at least 1/2 an inch of the screw sticking out from the other side of the cabinet door. This is the reason why the knob keeps coming loose.
    • Place the Phillips Head screwdriver onto the head of the screw and turn it counterclockwise.
  2. How to Repair a  Cabinet Door Knob: 步骤 2 中的图像 1,2 How to Repair a  Cabinet Door Knob: 步骤 2 中的图像 2,2
    • If the screw looks too short, open the cabinet and see if the screw is all the way in. If not, screw it back in (then skip to step 4). If it is fully screwed into the cabinet and it is still too short (meaning you don't see at least 1/2 a centimeter of the screw), you will need a new screw.
  3. How to Repair a  Cabinet Door Knob: 步骤 3 中的图像 1,3 How to Repair a  Cabinet Door Knob: 步骤 3 中的图像 2,3 How to Repair a  Cabinet Door Knob: 步骤 3 中的图像 3,3
    • Take the knob and the screw to a hardware store so they can give you the proper measurements.
    • Screw the newly purchased or old screw all the way into the cabinet door. Then twist the knob clockwise onto the bottom half of the screw once it's in the cabinet door. DO NOT screw the knob all the way on, leave 1/2 cm for the next step.
    • Turn the knob clockwise.
  4. How to Repair a  Cabinet Door Knob: 步骤 4 中的图像 1,3 How to Repair a  Cabinet Door Knob: 步骤 4 中的图像 2,3 How to Repair a  Cabinet Door Knob: 步骤 4 中的图像 3,3
    • Place the wood thread adhesive onto the knob that is outside of the cabinet before you screw it completely onto the door (this will guarantee that the knob will permanently stay on).
    • Leave about 1/2 of a cm between the knob and the cabinet door.
    • Be careful when using the glue. Try not to get it on your clothes, hands, or eyes.
  5. How to Repair a  Cabinet Door Knob: 步骤 5 中的图像 1,2 How to Repair a  Cabinet Door Knob: 步骤 5 中的图像 2,2
    • After placing the adhesive, let it dry for 15 seconds, then continue to twist the knob clockwise onto the cabinet until it is tight.
结论
To reassemble your device, follow these instructions in chronological order.
另外一个人完成了本指南。
附加文件
Shacoriann Graham
于01/26/20注册
151 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 430
