跳转到主内容
How to Repair Water Damage Under Your Sink
你所需要的
  1. How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 步骤 1 中的图像 1,3 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 步骤 1 中的图像 2,3 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 步骤 1 中的图像 3,3
    • Remove all items from under your sink.
    • Test for water leaks by gently pressing the cabinet with your fingers and seeing if it's wet and by looking for drips from the sink.
    • Clean the cabinet using a sponge or cloth with a cleaner or disinfectant of your choice.
  2. How to Repair Water Damage Under Your Sink: 步骤 2 中的图像 1,3 How to Repair Water Damage Under Your Sink: 步骤 2 中的图像 2,3 How to Repair Water Damage Under Your Sink: 步骤 2 中的图像 3,3
    • Use work gloves to sand the cabinet.
    • Use 100-grit sandpaper to sand the interior of the cabinets using a circular motion.
    • Sand until you can move your hand across the cabinet, and it feels smooth.
    • Clean the sand dust from the cabinet with a damp cloth or sponge.
  3. How to Repair Water Damage Under Your Sink: 步骤 3 中的图像 1,3 How to Repair Water Damage Under Your Sink: 步骤 3 中的图像 2,3 How to Repair Water Damage Under Your Sink: 步骤 3 中的图像 3,3
    • Apply wood filler with a paint tool making sure you don't apply too much of the filler.
    • You want the layer of filler to be smooth for when you paint over it later.
    • Use painter's tape to mark the areas that you don't want paint on.
  4. How to Repair Water Damage Under Your Sink: 步骤 4 中的图像 1,3 How to Repair Water Damage Under Your Sink: 步骤 4 中的图像 2,3 How to Repair Water Damage Under Your Sink: 步骤 4 中的图像 3,3
    • Use a caulking gun to seal the edges of the base. Gently press down on the applicator and follow the perimeter of the cabinet.
    • Use your finger to wipe all excess caulk off.
    • Let it dry for 30 minutes.
  5. How to Repair Water Damage Under Your Sink: 步骤 5 中的图像 1,3 How to Repair Water Damage Under Your Sink: 步骤 5 中的图像 2,3 How to Repair Water Damage Under Your Sink: 步骤 5 中的图像 3,3
    • Use an angle brush to paint all the edges with primer.
    • Use a roller to paint the rest of the cabinet with primer.
    • Let it dry for 1 hour or until it is completely dry.
  6. How to Repair Water Damage Under Your Sink: 步骤 6 中的图像 1,3 How to Repair Water Damage Under Your Sink: 步骤 6 中的图像 2,3 How to Repair Water Damage Under Your Sink: 步骤 6 中的图像 3,3
    • Use an angle brush to paint all the edges with the paint of your choice.
    • Use the roller to complete painting the cabinet.
    • Let the paint dry.
    • Place your items back under the sink.
结论
Now, you've got a good-as-new cabinet! You can reapply as needed if paint chips or dulls.
Chelsea Trevino
于09/24/23注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 42
过去 30 天: 185
总计 857
