跳转到主内容
How to Repair Warped Eyeglasses Arm Joint and Replace the Screw
你所需要的
  1. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 1 中的图像 1,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 1 中的图像 2,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 1 中的图像 3,3
    • Select a screw from the assorted eyeglasses screws box to begin the size-fitting process.
    • Start from the smaller sizes and work your way up until the screw body fits in the eyeglass frame hinge.
  2. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 2 中的图像 1,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 2 中的图像 2,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 2 中的图像 3,3
    • Place the screw into the end piece of the eyeglasses.
    • If the screw does not fit, repeat Steps 1 and 2 until you find a match.
    • Set the screw aside once you have the perfect fit.
  3. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 3 中的图像 1,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 3 中的图像 2,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 3 中的图像 3,3
    • Position the pliers so that both sides of the arm joint are on the inside of the pliers.
    • Apply slight pressure to the pliers to bend the warped arm joint back into place.
    • Too much pressure might break the arm joint or make the arm joint too tight for the next step, so be very mindful about the pressure!
  4. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 4 中的图像 1,2 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 4 中的图像 2,2
    • Align the arm joint to the end piece of the eyeglasses.
    • If the two pieces do not align or the fit is too loose, repeat Step 3 to adjust the arm joint.
  5. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 5 中的图像 1,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 5 中的图像 2,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Place the screw through the arm joint and end piece using tweezers.
  6. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 6 中的图像 1,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 6 中的图像 2,3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: 步骤 6 中的图像 3,3
    • Tighten the screw with the screwdriver.
    • Depending on your eyeglasses screws, choose the appropriate screwdriver size and shape.
结论
To disassemble your device, follow these instructions in reverse order.
Jaclyn Nguyen
于02/01/23注册
133 声望
撰写一个指南
团队
UC Davis, Team 4-4, Andersen Winter 2023 UC Davis, Team 4-4, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S4G4
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 72
总计 2,226
